Sony 9000ES new 2.01 software.
Discussion in 'AV Receivers & Amplifiers' started by Marky UK, Dec 1, 2000.
Tags:
  1. Marky UK
    Marky UK
    If you own a Sony TA-E9000ES processor/pre-amp, then you need the latest version 2.01 software.
    My kit arrived today from USA, installed and working perfectly, certainly improved the sound, especially with 2 channel digital sources.
    Adds 'virtual' EX 6.1 modes etc.
    You have to pay for this upgrade, as it includes a new 'simple' remote with the kit.
    Price is about $100 US + delivery.
    Some links:
    http://pub7.ezboard.com/faussiedvdandhtforumsonytae9000esinformationforum
    http://www.planetaudio.net/tae9000.htm
    Good luck finding a kit!
    Mark.
  2. D.Jay
    D.Jay
    I too have the 2.01 ( VUCD) upgrade kit and have done for a month or longer [​IMG]
    If you have a E9000ES make SURE you have 1.18c, and then order 2.01.
    The multitude of decoding fixes, and the general improvement in sound quality ( across all multichannel & Surround Off modes ) makes this NECESSARY for EVERY E9000ES owner! Don't let Sony "support" ruin your experience w/ what is otherwise one of the best Pre/Pro Combos for price [​IMG]erformance EVER seen!
    D.Jay
  3. charles
    charles
    Jul 6, 2001
    1,431
    63
    norwich
    +204
    Saying i buy the pre-power combo,where can i then buy the upgrade kit?
