Sony 900 DVD Player
Discussion in 'Blu-ray & DVD Players & Recorders' started by STW, Aug 1, 2002.
  1. STW
    STW
    Could someone tell me if this player can play DVD-R? I know that the specs on the Sony web site say it does, but I'd prefer someone who has a player to confirm it for me.
    Thanks in advance.
    Simon
  2. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,643
    London
    +477
    yes it does.
    I have the DMR-E20 to burn and they work fine on my NS900.
    Only some very, very cheap quality DVD-R's won't be recognised in the Sony.;)
  3. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    702
    Norwich
    +11
    could you tell me please what dvd-r do you use in your sony 900...
    i must have had some of the very, very cheap quality ones (unbranded... from work) which, as you quite rightly suggest, don't work.
    matthew
  4. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,643
    London
    +477
    Any gen 2 and beyond will work in the Sony.
    Princo, Datasafe, FWS, Whitelabel etc etc.tend to have good compatibility.
    I had some unbranded ones, think they were Vivastar. Which are cr*p for recording and compatibility.
  5. STW
    STW
    Thanks for your replies. I have mainly TDK and some un-branded Princos, burned on DMR E20, so I think I should be safe enough.
