Sony 890 recorder - poor EGP & non func G+
Discussion in 'Blu-ray & DVD Players & Recorders' started by m0bov, Feb 8, 2009.
  1. m0bov
    m0bov
    Aug 24, 2005
    Hi all, Dads got the new Sony 890 recorder, the digi EPG seems quite poor compared to the guide plus. There is no list of fav progs or a profile.
    Also, the G+ will not download the grid, I have plugged in the anlogue tuner direct from antenna, teletext works fine and ITV1 is labelled and tuned correctly. Any other ideas?
    Is there a better digital egp guide on other makes/models like the guideplus?
    James
  2. ramjet
    ramjet
    May 21, 2006
    3,761
    +622
    the correct method would be to daisy chain from digital out to analogue in on the back of the 890 , using another male to female coax lead , then up to the tv
    also make sure you set the host channel to itv1 in the menus
    I prefer the digital epg myself , but bear in mind that different manufacturers have a different type of epg , so on the panny you get a different one again and cannot change it
    on the sony or pionner you have a choice of two
    on a vcr you have none , so any is better than nothing
