sony 860 picture problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by larrybelfast, Sep 9, 2007.
  1. larrybelfast
    larrybelfast
    Sep 9, 2007
    13
    I am new to dvd recorders and this problem may already been posted. I have had the sony 860 for a few months but have only used it in a very basic way e.g hard drive recordings, watching sky news. A few days ago we loaded a dvd of my son's wedding pictures and the photos suddenly all turned blue/green (as if no reds in the picture). We thought this was a faulty dvd disc but now even just watching sky news on freeview the picture intermittently turns blue/green and may return to normal after a while.
    Help!
    larrybelfast
  2. Towner
    Towner
    Aug 31, 2004
    647
    +64
    How do you have the 860 connected as it sounds like a faulty/loose lead??
  3. larrybelfast
    larrybelfast
    Sep 9, 2007
    13
    thanks for your interest. Just checked the fairly complex wiring as follows:
    Coax aerial into old analogue box ( i get eurosport cycling on it) out to Ntl digital box, on to DVD recorder and into TV coax
    Scarts
    Analogue box to DVDR line 3
    Ntl VCR scart socket to DVDR line I
    Ntl TV scart to TV scart input (single scart input - needed to switch to NTL)
  4. Towner
    Towner
    Aug 31, 2004
    647
    +64
    Have you checked all the leads are connected fully? Your setup sounds rather complicated, have you made use of the HDMI output?
  5. larrybelfast
    larrybelfast
    Sep 9, 2007
    13
    thank you very much for your help. I have checked leads and have had no problem since doing so. however, since I only have an older crt television, is there any way of using hdmi output?
    thanks again
    larry
  6. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,153
    +7,095
    This is a problem with your TV - not of any of the associated equipment.
    Intermittent loss of red drive. It requires professional attention.
  7. Towner
    Towner
    Aug 31, 2004
    647
    +64
    The only CRT TV's I know of with a HDMI input are some Samsungs and possibly some European Philips. As Gavtech says it could also be a problem with the tube in your CRT, time to move to a LCD or Plasma!!!!
  8. larrybelfast
    larrybelfast
    Sep 9, 2007
    13
    thanks again but even though i need a new tv i am not convinced that it is the tv - it only happens when watching something from the DVDR and not on e.g. ntl box direct to tv
    larry
  9. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,153
    +7,095
    From where were you receiving the Freeview news that exhibited the fault?
  10. larrybelfast
    larrybelfast
    Sep 9, 2007
    13
    sky news on the freeview tuner in the DVDR but also fault occured when playing DVDs
    thanks
    larry
