Sony 735 CD-RW
Discussion in 'Blu-ray & DVD Players & Recorders' started by paiger, Jan 23, 2002.
  1. paiger
    paiger
    I have found that my 735 will play Nashua CD-RW's when copied using Clone CD. This is the only brand I have found to work although most I have tried have been CDR's. Anyone had any other success?
    Steve
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,576
    Somewhere in South Yorkshire
    +6,097
    In general, single-laser DVD players are much more likely to work with CDRWs than with CDRs. My old Pioneer 505 worked fine with every CDRW I put in it, and never worked at all on any CDR.
  3. Doubledoom
    Doubledoom
    I haven't found a CDRW that hasn't worked.
    Only Princo brand CDRs are a reliable CDR to use on the Sony.
  4. paiger
    paiger
    Hmm, and there's me thinking I had found the Holy Grail. Cheers you guys.
    Huh.:)
  5. Fartpants
    Fartpants
    Why does this f$$$ing Princo bulls**t come up every time.
    Reliable NO NO NO NO NO NO NO NO NO NO NO NO NO NO
    F***ING NO, I wasted money on buying those s**tty discs.
    Yes they may work with some Sony DVDs, but YOU CAN NOT RELY THAT THEY WILL WORK ON ALL SONY DVDs.:mad: :
  6. paiger
    paiger
    So, are you saying that they are reliable or they aren't?
  7. Doubledoom
    Doubledoom
    The work on the Sony x25 range and should work on the x35 range as there isnt that much difference between the models.
  8. Fartpants
    Fartpants
    It's OK I've taken my tablets now,
    I read a post here that by some muppet that said 'Princos would work on all Sony machines' they don't, they might on some they don't on all.
    Buyer beware.
  9. Leeray3
    Leeray3
    Jan 22, 2001
    149
    London
    I also own the Sony 735 and would like to state that Princo discs as far as I'm concerned do not work on this player. I was chuffed to read that these discs worked so I ran out and bought a some. When I tried to play them I was gutted.
    I have also tried a number of different CDRW brands on this player and none of them have yet to work. :mad:
  10. LV426
    LV426
    Jul 14, 2000
    13,576
    +6,097
    Are you SURE that it is the CDs that the player won't read, and not the FORMAT of the DATA you are putting on there?
  11. Doubledoom
    Doubledoom
    CDRWS and Princo CDRs should work on a x35 based machine.
