Sony 735 and Jpegs
Discussion in 'Blu-ray & DVD Players & Recorders' started by nunew33, Dec 17, 2002.
  1. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    I read on another thread that I could create a photo based CD by using nero to create SVCDs or VCDs with JPeg.
    Has anyone done this successfully with the Sony735?
    I tried it with Imation and Memorex and it didnt work. Tried it with a software DVD player and cdrom and they worked. SO can only assume its the Sony. VCDHelp.com states the 725 can read VCD and SVCD, are there limitations to this that Im overlooking? Are there Nero settings I should be aware of?
    Finally does the sony read PhotoCDs and how do you burn these? Are they a kodak proprietary thing?
    Has anyone managed to get their Sony735 to act as a viewer for a digital photo album?
  2. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Try with cd RW's
    Think easy cd creator will make photo cd's.
  3. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Thanks, CD-RW got me further. It got me as far as the player telling me it was svideo but not showing me any image.
    I trued with menus then without. Both times picture timings were ingfinate. I will try again tonight on timed settings.
    If only Id bought aan acoustic solutions £70 special then all would be ok
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,576
    Somewhere in South Yorkshire
    +6,097
    Use CDRW.
    And, use Nero to create a STANDARD VCD (not SVCD). Drag your jpgs into the CD layout and Nero will do the rest.
    Note that the VCD format allows for twice the resolution on stills as it does for movies ie 704*576 PAL - which is as good as DVD.
  5. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Thanks for that Nigel, I will try that tonight!
  6. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Success. Menu doesnt seem to work, but I have access to the pics
  7. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Just bumping as now Im curious as to why I cant seem to use the menu. navigating through several pics seems tedious without a navigation method. Is there a way to use the VCD menus. If there isnt is this a "-ve" feature of VCD in DVD players or a -ve feature of the sony?
