Sony 725 Firmware
Discussion in 'Blu-ray & DVD Players & Recorders' started by Mike Dando, Oct 9, 2000.
  1. Mike Dando
    Mike Dando
    I have a Sony 725 DVD player which is
    now exhibiting the dreaded lip synch problem.
    How can I tell which version of firmware my player has?
  2. Spookyville
    Spookyville
    Jul 20, 2000
    262
    Bradford, UK
    +8
    Press <Title>, <Clear>, <Power On>
    each button after one another ( not all together ) on the remote while the player is powered off.
    After the combination the player powers up into the service menu.
    Be Carefeul !
    Where did you buy the player from ? And what films are now experiencing the lip sync problems ?
  3. Mike Dando
    Mike Dando
    I got the player from Musical Images in December 99.
    I have seen lip synch problems on MIB R1 (DTS) & The Mummy R1 (DD)
  4. Guest
    The Mummy is quite common, Saving Private Ryan DTS and Bowfinger are the discs I've seen it on. Autocalib cleared them all up.
    [email protected]
  5. Mike Dando
    Mike Dando
    Excuse my ignorance.
    What/Who is Autocalib ?
  6. M.Joshi
    M.Joshi
    Oct 10, 2000
    249
    Harrow.
    +9
    What is 'Lip Synch'?
  7. Tintin
    Tintin
    Neil,
    Autocalib cleared them all up for a while. But the problem does not go away completely. I did just that only to find out more lip sync problem on other titles. Have had my player upgraded recently and the problem seems to have disappeared.
    Regards.
    [/B][/QUOTE]
  8. Tintin
    Tintin
    M.Joshi,
    Lip Synch is when suddenly the sound is out of sync with the picture!
    Regards.
  9. Mike Dando
    Mike Dando
    I have accessed the service menu as
    mentioned by Spooky_uk. The menu had a versions option.
    Choosing this option displayed quite a few version numbers.
    I am guessing that the SYSCON is the one I am looking for. It was 1.8
  10. Tintin
    Tintin
    You need the 2.6 upgrade which should clear your problem.
