Sony 725 and RGB Scart
Discussion in 'Blu-ray & DVD Players & Recorders' started by mjn, Sep 28, 2001.
  1. mjn
    mjn
    May 24, 2001
    22,433
    Herts, England
    +10,470
    I'm using a RGB scart to go between the DVD and TV, however when i use this, the picture shifts to the left and up, by 1 inch on both occasions...anybody any suggestions....i've tried 2 TV...1 a sony, and the other a Daewoo....
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    RGB shift seems to be a problem discussed fairly frequently on this forum but mainly pertaining to digiboxes.
    Presumably the official answer would be to get a service engineer to adjust the TV set but you can access the service menu if you know the access code and adjust it yourself.
    There will be postings elsewhere telling you how to access the service menu that should also give you a warning that you could mess up the TV if you alter the wrong things.
    regards
    Ian
  3. Doubledoom
    Doubledoom
    The fault is with the television, not the dvd player.
    RGB picture shift is talked about often. Some sets do have workrounds/fixes, some do not.
    What tv do you have?
