Sony 510 & Sky+
Discussion in 'Blu-ray & DVD Players & Recorders' started by Red1989, Oct 27, 2005.
  1. Red1989
    Red1989
    May 25, 2005
    17
    Connections problem/question!
    when connecting the sony 510 to the sky+ box i wanted to go from the tv scart socket (RGB) to the 510 line in (3). however, the sony manual says that for bskyb tuners you have to connect from the vcr scart socket (not RGB out).
    Having tried it, the set up wont work if you go from the tv scart. Am i missing something or does this mean its only possible to record on to dvd from sky+ at non-RGB scart performance?
    any ideas or anyone with the same set up?
    red
  2. johnmccoy
    johnmccoy
    Jan 25, 2005
    17
    Ballynahinch
    Hmm.. Don't know why you are having problems with this. I have the exact same setup, scart from TV out on Sky+ to Line 3 on back of 510 (RGB turned on on both devices), scart from 510 out to TV. I get perfect RGB at the TV even when Sony is in standby.
    Is the line3 input on the Sony setup correctly - I'm at work so can't look up how this is done but I seem to remember that you have to setup the input mode in the system menu on the Sony.
  3. Red1989
    Red1989
    May 25, 2005
    17
    thanks for that, at least i know its possible. i will take another look this evening...
  4. Supersonic
    Supersonic
    Jan 5, 2005
    1,162
    Surrey
    +219
    I have a similar set-up, my ntl 'tv' scart socket goes into Line3 in on the 510 and the Sony records and passes through RGB fine - even in standby as johnmccoy says.
    If you have the component out set to 'on' or Auto (i.e. not off), it won't let you do RGB out to the TV though.
  5. Red1989
    Red1989
    May 25, 2005
    17
    all working. thanks...
  6. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    The correct method of connection should be Sky+ (SCART) TV and Sky+ (SCART 2) DVDR (SCART) TV.
    Then RF Sky+ to TV to watch 1-5 while recording in RGB any other channel.
