Sony 50 inch widescreen rear pro ?
Discussion in 'General TV Discussions Forum' started by nickoff, Jul 2, 2002.
  1. nickoff
    nickoff
    Gidday again from "Down Under".
    Later this month, Sony are releasing a 50 inch widescreen rear projection tv in Australia - model KP51PS2.
    This link should take you there:
    www.sony.com.au/content.asp?go=products.asp
    Can anyone tell me if there is an equivelent model to this in the UK/Europe or has it come in from the US?
    It seems from time to time we get some UK models and some from US (eg. the Denon DVD 1600 in Oz is the non-progressive UK model with scarts etc).
    I was wondering if this TV originated in the UK and if so, has anyone seen it in action / reviews etc ???
    Cheers.
  2. Bal
    Bal
    Mar 10, 2002
    2,181
    Berkshire
    +317
    This is a larger verison of the 44PS2.
    However from my experience I would never go for a Sony TV again. I had my set replaced 3 times and each time there was cosmetic damage and screen imperfections which could only have happened before the set left Sony.
    On paper the Sony set should be a killer but in reality it was a different scenario altogether.
    I went for Toshiba in the end and haven't regretted it for a sec.
    Good Luck mate
    Bal
