Sony 5.1 - Colour Coded Speaker Connectors
Discussion in 'Home Cinema Buying & Building' started by dishywishy, Jan 15, 2008.
  1. dishywishy
    dishywishy
    Hi There,
    Im new to the forum, ive just got my hands on a 2nd hand sony 5.1 s/sound system (DAV-SA30)
    Only problem is that the colour coded speaker connectors that plug the speakers into the unit have been snipped off, i still have them though.
    I cant seem to detatch them from the little bit of wire they are on, even if i could i dont think id be able to get them onto the new wire.
    Does anyone know where id be able to get hold of new connectors?
    Many thanks
    Dishy
  2. twe
    twe
    Jan 7, 2007
    220
    +6
    ask sony?
  3. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    I dont think they would sell you them,as its more prudent to have to buy a new unit.
    what you could do ,is possibly solder the ends back on again,joining the speaker wire,to the little piece of wire still attached to the clip.
  4. dishywishy
    dishywishy
    Thanks, i think'll have a crack at connecting them via connector blocks first & see how that goes but if not i'll give the soldering a go.
