Sony 48 a9 or LG c1
vallumlj
Think I have chosen between these two tv it will be going on a wall in a loft room so lots of light. I will not have room for a sound bar so need the sound to be good and it will also be going on the wall. It will be for general tv and no gaming.
Out of the two above which one would you go for. Is there another tv you think I should consider ?
Dodgexander
Neither have more than average sound quality. Its not until you reach the higher end larger models that they do like the A80J/A90J or LG G1. It will be average on both TVs, which may or may not be okay for you depending on what you're used too.
I'd go for the LG if you want a TV for gaming, more future proof and with better smart TV and the Sony A9 if you're a sport fan or aficionado for good motion.
Both TVs will be very good for movies and TV watching, couldn't pick a winner there...although if you use the upscaling of the TV then the Sony may have the edge.
