bigvern123
when I view my sky HD on the TV (direct HDMI) connection and have the tv set to "fill pixel" view I get a noticeable blue vertical line right down the extreme right hand side of the screen, its very thin but still distracting.
I can change this setting to normal, this gets rid of the line, but its not what I want as the picture is then slightly scaled and therfore not as good.
When I view my Popcorn hour (another HDMI Source) with the same setting its fine,, I have swapped cables and hdmi ports but the sky box still puts out the blue line
can someone elese try the settings and let me know if you get the same ??
any ideas anyone, is it a problem sky box, tv or is it a knwon issue, tried searching but couldn't find anything
other than that the TV is top drawer
cheers..
cheers..
