Hi everyone, I got my 46d3500 last friday , as the set is a bit bigger than my previous 42" panny plasma (panel only no speakers) Its a bit higher on the wall when mounted over my center speaker (on fire mantel).
I am wanting to use the built in speaker as a center speaker so I can mount the tv a bit lower, my amp has a line out for the center but as I use the pc input for my Htpc and the component for sky/consoles I would need to split the center feed to the 2 different inputs on the tv, im fairly sure this will work as it will only be using 1 input at a time. Any suggestions of an easier way before I go get my soldering kit out , and is the speaker up to being a center speaker , i currently have a mission M71c center.
Cheers.
Cheers.
