Sony 43XE comparison help
Discussion in 'Sony TVs Forum' started by bjd, Jun 1, 2017.
  1. bjd
    bjd
    Feb 4, 2002
    2,859
    N. Ireland
    +866
    was just browsing Currys and came across these two models from Sony, the
    KD43XE8077SU and the KD43XE8004BU. I presumed the SU was the silver version and the BU was the black version. But, looking at the comparison page here:
    My Currys Comparison
    it says under "processing rate" it says that the SU is 400Hz and the BU has "Motionflow XR 100 Hz" Also under the "4K Ultra HD compatibility" it says the SU has "- Video CODEC: HEV
    - 4K Upscaling picture enhancement" WHile the BU part is blank. There are also differences in the connections - The SU has 4 x HDMI 2.2 and the BU has 4 x HDMI 2.0. There are other slight dfferences as well/
    So, does anyone know anything about these two TVs and is either of the two models decent TVs worth looking at?
    Brian
