Sony 40W4000 or Samsung LE40A686
flash-harry
Firstly, thank you for taking the time to read this.
I had made my mind up on getting the Sony 40W4000U after reading 5 star reviews in 3 of the current LCD/plasma/home entertainment magazines.
Found it for £779 in Richer Sounds, which is on a par with deals on the net, however it needs to be ordered in from a warehouse. Went to order it this evening when the assistant at Richer Sounds was very assertive in telling me that the A686 was a far better TV and was only £20 more than the Sony. However, only one in stock and none on display- they 'lose money' when they open them.
Firstly, is the 40W4000U the identical model to the 40W4000 (I appreciate that some retailers leave off some suffixes)?
I can't find many reviews of the Samsung, and other than style doesn't seem much different from the 656 (I've read the thread on the on going debate). I was also told that Samsung make the Sony (I assume just the panel- or the entire thing?) is this true?
Which TV do you consider to be best? The majority of the time, intend to watch freeview, with a later blu-ray purchase. I also have a Humax 9200t PVR, so I wonder if anyone who has either has knowledge of handling of other scart devices.
I have a Wii and have contemplated a PS3- will both handle these equally well? Any comments on PS3 as a blu-ray solution welcome.
I've looked at Samsungs in stores and have found the colours to be oversaturated in a way. I have noticed previously that sometimes the Samsung picture looks almost it has a moving 'grain'- is this also the case on the 686 (apologies if this sounds vague).
Thank you.
ChrisGgr
My suggestion is the even better than both 40W4500 for just £869 from richer sounds
tomiK
Established Member
Hi, I have been in this exact same situation a week ago. I eventually decided to go with the Sony over the Samsung. The thing that put me off the Samsung was the purple tint people were getting, and the fact I already own a 32" Samsung LCD and wasn't that impressed with it. For colours alone the Sony is hands down better, very natural looking. My only gripe with the Sony is it doesn't have a very good freeview tuner compared to the Samsung. Other than that, no complaints.
Also, if you are interested I did a short review on the Sony KDL40V4000: http://www.avforums.com/forums/showthread.php?t=825064&page=4
Edit: Just realised you are talking about the W4000, but needless to say I have read they are very similar.
ChrisGgr
-Ad-
The richer sounds reps will push whatever they need to get rid of and what makes them the most profit.
Sony over the samsung would be my choice :thumbsup:
ChrisGgr
Are there any key differences between the two Sonys?
100Hz,higher contrast and network capabilities.Having seen both the price difference makes W4500 really worth the extra
flash-harry
Does the network connection do anything exciting?
Edit: I see that you can se it for photos/music- is this easy to set up e.g. IP address or sharing folders- can this be a PC or a harddisk and is software needed?
ChrisGgr
a pc with DLNA,but you can also view photos and listen to music from a USB.Also the overall performance is even better than W4000
Klipsch The Sevens Powered Speaker Review Coming Soon
Back
