Sony 40v4000 problem with HD
Discussion in 'Cable TV & Virgin Media TV' started by Rognvald, Feb 8, 2009.
  1. Rognvald
    Rognvald
    Feb 8, 2009
    3
    Glasgow
    Hi there, Just upgraded to a 40" Sony from 32" Samsung and when I connect throught the HDMI Picture is perfect but regularly the picture drops and then refreshes so you get a second of black screen. Its as if the tv is polling to look for an input. First I thought it was a problem with the VM signal but after re-connecting Samsung its fine. :confused:
    Anybody got any words of wisdom? Think it must be the TV but not sure what the problem is. Been throught the menus repeatedly ad can't find a thing.
  2. essjay
    essjay
    Jun 7, 2006
    925
    43
    +110
    I had the same problem with my Sony TV (46W4500) I changed the HDMI lead and all was fine.
  3. Rognvald
    Rognvald
    Feb 8, 2009
    3
    Glasgow
    OK thanks for that. Still using the original that came with the V+ box. Not sure of the quality though.
  4. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    It should be more than adequate for the job. Worth checking with another one though.Never had any problem with a Virgin+ and my Sony 4000/32"
  5. alsina
    alsina
    Nov 30, 2008
    3,796
    +605
    It will be the HDMI cable causing the problem. Change it for a decent one and all will be well.
