sony 405 hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by si325i, Mar 10, 2003.
  1. si325i
    si325i
    do any of you know if it is easy to unlock my sony 405 player to multi region? if so how. thanx loads..
    £50 quid to unlock, my ar5e!!
  2. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    As far as i know there are no remote hacks for sony dvds.
  3. mike80
    mike80
    Mar 10, 2003
    9
    3
    Lappeenranta
    Actually I have a remote control which is able to hack sony dvds.
    It's OFA 6 and I have the right codes in it.
  4. si325i
    si325i
    sounds good to me where can i get one and how much? does it come with the code?
  5. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    What i meant was that you cant with the standard sony remotes
  6. huboutsailing
    huboutsailing
    So did you find a way? I to have a DVPNS405.
    :confused:
