Sony 36FS76 question.
Discussion in 'General TV Discussions Forum' started by godi32, Jan 20, 2003.
  1. godi32
    godi32
    Hello,
    I can buy a Sony 36FS76 from a guy who says he has bought this television a week ago but has now decided he's going for a plasma (clearly a maniak like all of us :) )
    He sells his Sony for 2000 Euro or £1280. This price includes an extended warranty of 5 years.
    How can I be sure that this sony has no hidden defaults and is this a good bargain? Can you give me advice on what to look out for if I'm going to see this television?
    Thanks,
    Dirk
  2. godi32
    godi32
    Is it possible for all owners of this model to give me some tips please?!
    I'm going to see this guy on Friday.
    Thanks,
    Dirk
  3. Bogside
    Bogside
    Sep 20, 2002
    3,137
    Stockport (ex Derry)
    +417
    Why don't you do a search on SOny 36FS76 and problems that some have had will be highlighted there!
  4. cdave
    cdave
    Dec 10, 2002
    306
    There is one positive way to look at your situation. You are in the position of getting a nearly new set and have the opportunity to see the picture. You will see for yourself if the picture is good or not. I would also put the set on mute and see if there is any annoying sound, whistle of buzz. I would ask the seller to have the set on a couple of hours before you arrive to warm it up. That is when noises come to light in my experience.
    Put the set on 4/3 mode and see if the line is straight down the edge of the picture. How much are you saving in your area and is the warranty transferrable? In the Uk I do not think you would have the same rights as the original buyer, probably the same where you are?
    As noted above, most of what you need to look for can be found on many other posts on but the above is what I would look for first.
    Let us know.
    Dave
