Quantcast
sony 32fx68
R
rossp
I have purchased a sony 32fx68.In all i am very pleased with the set, the only problem i seem to have is a horizontal line that appears accross the screen in random places at random times. Is this something which can be cured or will the set need to be returned. All speakers have been moved away from the tv.
Many thanks ross
P
Paul Atreides
Could you decribe the line in more detail?
Colour, size ect..
R
rossp
it's about 2/3mm wide and shows up as a lighter colour than the background i.e dark green backgound line light green. It shows up on dvd, video, tv and sat but appears in random places and will dissapear after a few hours of viewing.
P
Paul Atreides
Sorry I'm not sure about this one, it might have been setup badly in the factory or there's some dodgy circuitry.
Maybe someone else can help you.
Jules
You don't have a DECT phone near by do you?
I had a similar problem which was solved my moving the DECT phone and its base station away from the TV.
R
rossp
Thanks alot for your help guy's, you were right Jules moved the phone away no probs now. That would have probably been the last thing i moved thanks again ross
Similar threads
