Sony 32FX66 widescreen settings
Discussion in 'Televisions' started by neilybealy, Feb 24, 2003.
  1. neilybealy
    neilybealy
    Jul 9, 2001
    1,539
    48
    Kent
    +55
    hi all
    i'm a little confused (not hard i know)
    my old panansonic i just left on auto and when a widescreen prog was broadcast on channel 4 it changed to fill the screen and "wide" was displayed in blue
    on the sony you've got smart and wide and i'm not too sure the difference as on some programs some of the screen either top or bottom is chopped off
    cheers
    neil
  2. MattDX
    MattDX
    Smart 'diddles' the screen so non WS images appear WS but not streched. You'll lose a little bit at the top and bottom. Wide is for images that are 16:9 (DVD, Consoles etc) this setting on a non WS image will stretch it making people look fat and wide.
  3. neilybealy
    neilybealy
    Jul 9, 2001
    1,539
    48
    Kent
    +55
    ok cheers
    it doesn't look like it's going to be as friendly as my old panasonic then as i just used to leave it on auto
  4. MattDX
    MattDX
    Doesn't the Sony have an Auto setting. Mine's still in the box :( but I've read the manual and think I saw an auto setting.
  5. neilybealy
    neilybealy
    Jul 9, 2001
    1,539
    48
    Kent
    +55
    hi again
    this is what i'm confused about....
    in the menu somewhere there's an auto setting but then when you press the widescreen button it switches between the smart zoom 4:3 wide etc settings
    on my old panny one of the settings was AUTO which was easy !
    neil
    :D
  6. HowieC
    HowieC
    Jun 9, 2002
    249
    London
    Select auto format to ON
    Switch to a 4:3 programme and use the blue button to select 4:3 mode if not already set.
    TV should now switch automatically between 4:3 and widescreen, you only need the blue button if you want to switch to another format manually.
  7. bobones
    bobones
    Jan 15, 2002
    453
    +7
    Say I want all 4:3 displayed using "Smart" all the time and all widescreen using "Wide". Can this be done? It seems I have to switch from 4:3 to Smart on each channel, but after a while it seems to remember I want "smart" on a particular channel.
  8. Lesmond
    Lesmond
    Jan 29, 2003
    131
    +3
    I think the Sony remembers your last manually set picture mode for each channel.
    If you prefer the 'smart' mode, you should turn the the auto format feature off, visit each channel and select the smart mode. I think even when you do this, if an anamorphic DVD is being played, the TV will still switch to widescreen mode if required.
  9. bobones
    bobones
    Jan 15, 2002
    453
    +7
    Cheers Lesmond. Switching autoformat off does the trick. Now 4:3 material from my freeview box is always shown using Smart but the tv still automatically switches when a channel shows a widescreen presentation. :smashin:
