Sony 32FX65 - strange behaviour with TiVo
Discussion in 'General TV Discussions Forum' started by EddyC, Jan 5, 2004.
  1. EddyC
    EddyC
    Sep 23, 2001
    23
    Dublin, Ireland
    A friend got a Sony 32FX65 for his bedroom over Christmas. It's working well, except for one really weird bit of behaviour.
    He is feeding the UHF output of his Tivo (located downstairs) to the new Sony (UHF channel 28, but other channels had similar results). As long as the Tivo is displaying live TV, everything is fine; however, as soon as the Tivo puts any sort of overlay graphics on the screen, e.g. the Live TV guide, or the main Tivo menu, the Sony gets confused and about 4-5 seconds later goes into standby mode.
    This is 100% reproducible. It can be triggered by someone downstairs using the Tivo remote, so no possibility of a Tivo remote code somehow upsetting the Sony.
    The standby LED doesn't flash once the set has shutoff. Also, the downstairs TV is a 36" Sony and doesn't have this problem when viewing the Tivo over UHF.
    Anyone else seen something similar to this? He'll be getting in touch with the highstreet retailer, but since all they'll do is offer to swap it for a different unit, I thought I'd check and see if this is a known 32FX65 quirk.
  2. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    It could be to do with the software on Tivo. 2.5.5 software has the facilty to record subtitles - sometimes this can cause odd behaviour with certain tvs (it is to do with the teletext chip on the tv).
    Get your friend to ring Tivo and ask for the software 2.5.5a (which removes the subtitle record feature from Tivo - and should cure his problem).
  3. EddyC
    EddyC
    Sep 23, 2001
    23
    Dublin, Ireland
    Hmm... very interesting; thanks! I'll ask him to give it a try.
    (Does anyone know an easy way to disable the teletext from the command line, without having to go through the whole upgrade procedure? He has a Tivonet and has a number of customisations, some of which would need to be redone if the unit was upgraded.)
    Eddy
