Sony 32FX60 Autoformat problem
Discussion in 'General TV Discussions Forum' started by pavlos, Jun 22, 2001.
  1. pavlos
    pavlos
    Mar 5, 2001
    11
    I currently have a Sony 32FX60 whichs has the following problem, when I watch DVDs (4:3)format like Star Trek and Space 1999 through the AV1 using the RGB setting connected to my Pioneer 636 after 15 minutes of play the TV starts to switch beetween the different aspects ratios, smart, 4:3, wide and even sometimes to AV2 and backwards, I have turned off both the AutoFormat and the specific autoformat off for AV1 i was told that should have solved the problem but it didnt, NOW THE the funny thing if I switch from dvd player menu from RGB to Composite the problem is gone, weird..
    Well any suggestions will be most welcome
    Thanks in Advance
    Pavlos
  2. AMc
    AMc
    Nov 20, 2000
    7,236
    Near Norwich
    +3,942
    I have exactly the same TV and I haven't seen this kind of thing.
    I've turned off all the auto formating (on the AV and in general) and not looked back since.
    You might find someone with more information at KV Tweak
    AMc
