Sony 32DX150 Colour Bleeding ?
Discussion in 'General TV Discussions Forum' started by iclarke, Dec 28, 2003.
  1. iclarke
    iclarke
    Aug 28, 2003
    16
    3
    Well I'm verrrry close to buying this TV, it generally seems to be popular and has a good range of features. Have read in the couple of reviews I can find on-line that it has a 'colour bleeding' problem ?!? Can someone tell me what this actually is, if it's true and if I should worry about it or not ? There are a few people on here that own this TV are'nt there ? How do you rate the picture ? I'll be watcing probably 60% Sky, 30% DVD and 10% Xbox / Gamecube ...
    Ian.
  2. jerkyboy
    jerkyboy
    I have just returned one of these sets, the colour bleeding with reds was terrible. There was a red blur to the right whenever red was on screen.
    And I have to say that the DRC made little difference to the picture.
    I am a fan of Sony but I think they are falling behind Panasonic in terms of picture quality.
    I have just ordered a Panny PD30, hopefully that will be better.
  3. harmunt
    harmunt
    Jul 26, 2003
    181
    Good luck on that one.
    When I looked at one in the Panasonic shop it was playing the menus for A Bugs Life. The Reds were bleeding a good 4mm to the right. Put me off immediately.
    Hopefully (for you) it was just a dodgy shop floor TV.
