Sony 325 R2 scart interference?
Discussion in 'Blu-ray & DVD Players & Recorders' started by js, Jan 28, 2002.
  1. js
    js
    I posted this as a reply to a thread about a Panasonic 28PL1 TV.
    I have a Sony 325 R2 (couple of years old now) hooked up to my Panny TV using a cheapo scart lead and RGB signal.
    I get these vertical faint lines which are not just vertical lines. What I saw tonight was almost like a heart monitor and also at different levels of the screen I get the following:
    ||||** ||||* |||||| |||||||||| - something a little like that. This is only coming from my Sony 325 DVD player, does anyone know what it is? Will getting a decent shielded one-way scart lead sort it out? The * are the same size as the lines and I am assuming they look like that as its hard to tell.
    I'd appreciate any ideas of what it is, I do not get this on normal TV or through my VCR.
    This happens when there isn't a DVD in the player as well. There is other interference as well but not very evident from the normal sitting position.
    Cheers for any pointers.
  2. js
    js
    Any ideas whatsoever ?:(
