Sony 32" FQ models !!!
Discussion in 'General TV Discussions Forum' started by welshwizard, Oct 31, 2003.
  1. welshwizard
    welshwizard
    I've just decided to take the plunge and swap my 8 yr standard JVC 28" for a 32" Widescreen.
    What a mine field buying a Tv can be , models, faults, best prices etc etc
    As always this site is very imformative , so i did a search on Sony 32" models,and its dragged up alot of p*ssed off Sony customers with regards to " scrolling bars " on the FQ models
    Can anyone tell me if this fault is model related,( and is it still out there ) or is it Sony related
    and is worth the extra ££££ on buying a Lowe ??
    My budget is about £900 !!!
    thanks to all
  2. kamza
    kamza
    Dec 4, 2002
    145
    Glasgow
    +6
    Hi welshwizard
    The only FQ model to stay well clear of is the FQ75...I'm one of the un-lucky owners of it and well ****** off.
    The FQ-75 was relpaced by the FQ-80 and by all accounts it's much better however it may be above your budget.
    Check out the FQ-70...cracking set and you should manage to find one for your £900.
    Hope this helps
  3. PaulJ
    PaulJ
    Hi There,
    I have an FQ70 and can highly recommend it. Hasn't suffered from some of the problems reported on here.
    Only thing I noticed is a small buzz. Buzz not noticeable when watching tv.
    Paulj :smashin:
  4. andrewmellor
    andrewmellor
    Dec 17, 2002
    1,533
    38
    Nottinghamshire
    +22
    I had one of the FQ75's.....it was a great set apart from the scrolling bars which were only really noticeable on a full totally black/very dark screen but was fortunate enough to have it replaced with an FQ80 by Sony anyway with which I'm very happy and would strongly recommend, it's a great set and looks very nice too!
    Good luck in your search
    Andrew
  5. mansell
    mansell
    Feb 11, 2002
    914
    28
    Bristol
    +39
    I too am a happy FQ80 Owner
