Sony 28DX30 cannot tune DTV channels
Discussion in 'General TV Discussions Forum' started by jfc, Jul 14, 2002.
  1. jfc
    jfc
    I've had the above for about 14 months and once i'd changed a few things to sort geometry its a good set in a half-decent AV setup (Mission fs2av and sony 1070 amp).
    I use NTL cable so not much use for integral digital decoder. But it should work and doesn't. So I thought I'd try and get it sorted.
    Problem is that it just wont tune in and find any digital channels since some10 months ago I plugged the ITVD CAM into it. Before then it was fine with free channels. Since then nothing at all. No digi channels. Normal analogue is fine. The aerial has been upgraded btw and as I say all was fine until I plugged the cam in.
    Any thoughts? Quickest cheapest repair route?
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Aghh!
    Official Sony service agent - ps tried a full power off yet?
  3. super7
    super7
    Mar 20, 2002
    165
    Banbury, UK
    +3
    I've got a 28DX40 and have only needed to do this a couple of times. Last night was the second time!
    Came home from work and nothing! no DTT channels, signal meter showing low. I even went to check the aerial was still there (I didn't think of trying the analogue channels at first - I never use them now)
    Turned it off at the wall, and 10 minutes later, truned it on and all was well. Strange....
