Sony 28cs70 need help
Discussion in 'General TV Discussions Forum' started by stokkum, Feb 7, 2005.
  1. stokkum
    stokkum
    Can anyone help me. I´ve just bought a sony 28cs70 and the problem I have is that i want the tv to play through my dvd home cinema system but when I put the tv on standby at night it looses the speaker settings in the menu. So every time I put the tv on I then have to go to the set up menu and turn the tv speakers off as they automatically return to on when the tv is put on standby. There must be some way around this problem as it´s very annoying to do this every time I put the tv on. I rang the sony service centre and the couldn´t help and said that this is normal. If this is normal then this tv is not home cinema friendly.
    The tv is model is sony kv28cs70b
    The cinema system is sony dav-s300
  2. DJ Mike
    DJ Mike
    Nov 25, 2004
    412
    +19
    This is actually a known problem with the CS70 - unfortunately there's nothing you can do to force your TV to remember the setting. Not very good, I know, but it's a software oversight on Sony's part.
    M;.
