Sony 1270 starts & then stops
Discussion in 'Projectors, Screens & Video Processors' started by AJ666, May 26, 2005.
  1. AJ666
    AJ666
    Bought this 1270 from Roland about 4 years ago. It's been brilliant until today when it started and then stopped. Each time I press start the fans run (all of them) for about 1 second and then the unit cuts out. Any ideas anybody ?
  2. parsonic
    parsonic
    May 27, 2005
    Are you sure very fan is running up properly?
    Don`t forget to look after the two in the powersupply.
    If all are fine you really have larger problem.
    Then something else is triggering the protectioncircuits.
  3. plasmatik
    plasmatik
    Hy
    Same a few weeks ago: it was a connector bad connected on main board:
    Verify .
    Sorry for my poor english. I'm french (nobody is perfect)
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    It does sound like a fan problem.
    Part of the protection on the 12** is that if a fan stops spinning then it shuts the unit down.
  5. AJ666
    AJ666
    Roland, thanks for your reply. As far as I can see, all 6 fans appear to start and then stop. Could it still be a fan problem ? Tony
