Sony 11HT
Discussion in 'Projectors, Screens & Video Processors' started by Pip_UK, Mar 31, 2002.
  1. Pip_UK
    Pip_UK
    Extremely easy to mount on the ceiling (Unicol Gyrolok mount).
    Extremely easy to use and setup.
    Extremely pleasing picture ... even with composite connection with NTL cable.
    Extremely pleasing picture ... even in a fairly bright environment
    Extremely pleasing blacks .. even with downlighters on using 1000 ANSI
    As you can guess from above .... extremely happy :p
    I chose the MDF route as I thought if it went wrong I lose £50 .. if it goes right ... I save myself £900. Pleased to say the MDF looks fab! ... saved myself a bloody fortune!
    Projecting a 98" image from 3.5 metres with no 'chicken-wire effect'.
    Will post screen shots when I get time
    Pip
  2. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    Hi im happy to read your good views on the sony as i have one on order makes a nice change from the panny
    I have a 8ft DA LITE screen a recent buy great pictures from my sanyo before i f_ucked it cleaning the dust out
    o well you live & learn
    will give my views when sony arrives from Germany
    pat:cool:
  3. gwbailey
    gwbailey
    PIP,
    I take it you mean MDF with Icestorm 5?
    If so, do you find the picture abit dull or
    is it ok?
    Lookforward to those screen shots!
    Cheers,
  4. Guest
    Pip,
    Great Choice!!
    BUT remember this,the picture you are now seeing is 40% of what the Sony is capable of!
    Via p.c. at 1366 x 768,after Avia calibration(Smart next...) the picture is brilliant!!
    Look at the Big Picture website for more...
    Doug
  5. jrwood
    jrwood
    hey check out my post titled Sony HT11 or Sharp 9000 or ....
  6. Pip_UK
    Pip_UK
    MDF is painted with Tate Matt Vinyl Stone (sold at B&Q). I chose this grey as it was a shade in between Icestorm4 and 5.
    To get the maximum screen size from a sheet of MDF, I made the frame on the wall first and slotted the MDF in. The masking frame wood was 1cm wider than the base frame to give a minimum overlap on the MDF (my frame was so tight it didn't need the overlap to hold in place!). I achieved a screen width of 216cm.
    The masking frame is painted with Internation Matt Black which is non-reflective. There is a faint overscan even on this but not enough to cause annoyance.
    Pip
