sony 10ht guys
Discussion in 'Projectors, Screens & Video Processors' started by leon, Aug 9, 2001.
  1. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    a simple question ,my sony 400qm cant switch between svhs and composite "75ohm" can the 10ht do this ,i have a lazer disc and vcr i want to use with the 10ht "when i get it "and they do not have svhs...........<br />thx
  2. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    On the VW10HT you can switch between:<br />Composite, S-VHS, Component, or Computer. All are single button presses on the remote.
    Hope this helps.
  3. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    thx for that m8e ,im glad it does that it will make life much easier <img src="smile.gif" border="0">
