sony 10ht/11ht owners
Discussion in 'Projectors, Screens & Video Processors' started by leon, Nov 18, 2001.
  1. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    hiya
    could you tell me if you use the sony mount for your projectors (pss-610) and is it any good i found it for £204 at mr super ..
    i have seen these type http://www.unicol.co.uk/
    but i cant find the price ??of it (does anyone use this mount )and are they any good ,,
    thank you ...........
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    We've used both as we'd been using the Sony model and I thought it was crap. Unicol are the boys for after market brackets!
    The thing we used for the Oil Platform install with the VPL10 was a Unicol bracket!
    Gordon
    Gordon
  3. Dangerous
    Dangerous
    I have the Unicol mount. It is very good. Adjustable in every dimension you will need. Cost about £200.
  4. Metric
    Metric
    i have the sony official one, its fine, though not straight had to screw the bracket at an angle
  5. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    I got the unicol one and it does the job fine, although it was a bit too long even with adjustment so I had to take my hacksaw to it.
    Slingshot
  6. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
  7. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    It was fine to cut down, I actually fixed the top plate above the joists, for 2 reasons, the only way it can come down is if the ceiling collapses because the weight is actually on the joists rather than 4 wood screws, and secondly it looked neater because the plate is hidden and I just needed a hole in the ceiling for the shaft to go up.
    I think you can order different pipe sizes for the unicol, I just ordered the wrong one and forgot to take into account I'm 6'2".
  8. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    thx for that ..:) ill get one of them .
  9. Metric
    Metric
    the one in that install picture is the sony mount
  10. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    yes ,i liked the look of it but most people are saying the unicoil one is better ,i hope the unicoil looks as good ...
