Sony 1080 Receiver Crossover Settings
Discussion in 'AV Receivers & Amplifiers' started by DanAshmoreUK, Mar 31, 2003.
Tags:
  1. DanAshmoreUK
    DanAshmoreUK
    hey guys i was just wondering on what settings i should have for my 1080, 1st of all should i set the front speakers on small/large and what crossover settings should i have for my Front/Centre/Surround and Subwoofer settings, it gives me a range from 40Hz - 200Hz. On my actual subwoofer you can set the crossover from 50Hz - 170Hz as well as the volume controls???
    Please help, Im really stuck
    Ps: i think my setup should be in my sig if needed
    nice1
    ---Ashmore---
  2. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    A good starting point is... set all speakers to small, all the crossovers to 80Hz (speakers and LFE Cut) then turn the crossover on the sub as itself as high as it'll go (170Hz ). Like i say just a starting point...play some music/DVDs and have a tweak.
