Sony 1070 Woes
Discussion in 'AV Receivers & Amplifiers' started by ajw000, Jan 14, 2003.
Tags:
  1. ajw000
    ajw000
    May 16, 2002
    121
    Stirling, Scotland
    Well, after getting it about 3 months ago, i managed to snap the volume knob off it. Obviously its not covered with the guarentee so was wondering if anyone knew how much it would be to replace the shaft that has snapped?, the Sony shop wanted £20 just to look at it!
    Ive heard of a few people snapping these off so it seems like a bit of a weak spot to me!
    Ive manage to get a little metal rod to hold the knob onto the shaft, but it doesnt turn:(
    Another thing is My pioneer on digibox's remote has nearly packed in so I need to use the remote for my 1070 as the remote for this. The problem is I cant find the right IR set for the digibox, ive tried all pioneer sat and cable IR's, and none
    work, anyone know if it has the right IR freq built inand which one it is?
    and before anyone suggests a pronto, ive had one and sold it cos the missus
    wouldnt use it :(
