Sony 1070 sound problem/question
Discussion in 'AV Receivers & Amplifiers' started by Craig_Nike, Dec 31, 2001.
Tags:
  1. Craig_Nike
    Craig_Nike
    My 1070 has occasionally had a small problem which results in no sound whatsoever.
    What happens is that all of the small speaker/channel indicators in the display (small boxes with L.R.C.SL.SR ect) start falshing and no sound comes from the speakers.
    This has happened 2wice while playing MPEG DVD's (connected digitally) and recently when I plugged a VideoCamera into the front inputs.
    The fix is basically to switch the machine off and usually it works first time.
    Anybody experienced the same thing - any ideas ?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Sorry Craig but I haven't experienced that type of problem on mine.
    The only annoyance that I have had is when playing cd's through the DVD player. I don't like to listen in surround sound but the two channel stereo mode won't use the sub which is annoying if you have sub / sats.
    I have got around this by using the stereo movie DSP having first adjusted all of the parameters to remove all traces of processing.
    Ian
  3. Craig_Nike
    Craig_Nike
    Thanks Ian - I knew you'd take the trouble to reply.
    Glad you're not having any troubles. I will let you know what happens if I take it in for a check up.
    Let me ask you on the music through the DVD - I understand that 2 channel takes the sub out, but doesn't AFD just play music through 2 channel and include the sub ???
    I enjoy listening to music in Cimena Studio EX B - but importantly with Dolby Pro Logic turned off. Then I just set Centre speaker to -3 and I really like the effect....
    Jeez I love putting in dts 6.1 ES disks in and getting that 3/2+1 on the display !
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    No - I thought that AFD was supposed to decode in the correct format but it seems to think thyat cd's should be pro logic.
    Whilst I have seen the 6.1 decoding sign appear on the receiver I haven't actually heard it as I don't have a centre rear yet and am still undecided on whether it would be worth the trouble in a relatively small room.
    Happy New Year
    Ian
  5. Craig_Nike
    Craig_Nike
    Mate my machine plays CD's via Fronts only and sub with no decoding when I set AFD. - Strange that your goes to automatically to Pro Logic ?
    My room is 5x7mtrs and I really feel the centre rear works well - I have mine a nice shelf above my chairs.
    I dont know how you can resist the temptation to stick an extra speaker in there when the 1070 has the ampfliciation ready to go !
    I only have a cheap old midi system speaker there at the moment, so it didn't cost me any money to set up. (And it makes all my 5.1 friends jealous !)
    Best of luck with the new year mate.
