Sony 1070 IR codes for Force SAT receiver
Discussion in 'AV Receivers & Amplifiers' started by pligs76, Jun 3, 2002.
Tags:
  1. pligs76
    pligs76
    Does anybody happen to know whether it is possible to control a Force D-master 1122 Sat receiver from the remote of a Sony 1070?
    Its not in the list, but does any of the pre-programmed IR codes fit the Force receiver?
    Pligs76
