Hi all
Just some advice please.
I am reconfiguring my lounge and doing away with old stereo system attached to tv to be replaced by a Sonus beam.
The Sony does not have Arc so will be using the Sonus optical adapter.
My questions are:
1. Will I still be able to use the Sky Q remote control to control Sonus volume even though its using optical adapter?
2. Is my assumption correct that I would not be able to use built in Alexa to control volume of beam as this can only be done through an arc connection?
3. Any other comments/advice before I pursue this route. (If beam not suitable next option would be Q acoustics M3)
Many thanks!!
My questions are:
Many thanks!!
