sonotube
Discussion in 'Home Cinema Building DIY' started by cradleoffilth, Jun 19, 2003.
  1. cradleoffilth
    cradleoffilth
    does anyone know where to get a piece of sonotube in the uk? can't find it anywhere:mad:
  2. Exeter Man
    Exeter Man
    Cradle,
    AFAIK, Sonotube is basically PVC lined cardboard tubing, as used for casting circular columns and the like. As I recall, the last time I looked at some on a building site, it also had PVC on the outside, which would make it a bit of a pain to finish.
    Give Essex Tube Windings a ring on 01375 851613, and they should be able to tell you who is your nearest stockist.
    Regards
  3. cradleoffilth
    cradleoffilth
    thanks mate. i will do that.
  4. banners
    banners
    Jun 26, 2002
    439
    nottingham
    +16
    If you don't mind keep us informed as to how you get on. I'd be interested in playing with some if a viable option exists:smashin:
    cheers steve
  5. Exeter Man
    Exeter Man
    Actually, I think i'm slightly wrong - inside is usually black PVC lined, and outside is shiny white cardboard (not PVC).
    Regards
  6. avanzato
    avanzato
    Jan 21, 2003
    1,878
    Norfolk
    +60
    If you haven't found it already their website is here.
    It looks like they're flexible on the finishes available.
  7. cradleoffilth
    cradleoffilth
    i have contacted them and it is £65 plus postage. thanks for the help! :)
  8. banners
    banners
    Jun 26, 2002
    439
    nottingham
    +16
    For what dimensions? How thick is the section?
    cheers steve
  9. cradleoffilth
    cradleoffilth
    50 inches in length 24 inches diameter and can't remember the thickness though :D
  10. Exeter Man
    Exeter Man
    Ouch !!!
    You can get a serious amount of veneered MDF box for that sort of money.
    Is that the size you need ? If so, that's one Mother of a sub you're building - about 350 litres by my reckoning :laugh:
    Regards
  11. IronGiant
    IronGiant
    Jun 7, 2003
    53,058
    Oxford UK
    +29,004
    So how do these tubes work?
    In around 1987 someone told me you could get good base from a tube, so I bought six foot of 6" PVC sewage pipe, glued a really cheap 6" driver on it, connected it to the B speaker output of my hifi and was really rather unimpressed.
    I was a bit naive back then. :blush:
    Kind of crushed my DIY aspirations until RichH pointed me here a couple of weeks ago.
    Dave
  12. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Sorry Dave, I apologise for getting into all this nonsense! :devil:
    Sonotubes are basically the same as any other speaker enclosure - the tube shape makes them very rigid, and all that is needed is a top and bottom cap, so in theory they're easier to build (as long as you can cut circles!). The volume of the enclosure needs to be calculated just like it does for any other speaker. I think in the 'States, the tube stuff is a lot cheaper, hence their popularity. Do a google for "sonotube shiva" and see what I mean.
  13. jpwhaley
    jpwhaley
    Feb 1, 2002
    44
    Bristol
    I spotted a some contractors laying some of those yellow gas pipes yesterday so I asked them if they had any spare sections and walked away with a 6ft section . This PVC pipe is about 2ft in diameter with 1 inch thick walls so should be a cheap alternative to Sonotubes and probably stronger. Its certainly heavy enough. The contractors said they get lots of requests from people using them for speakers! Has anyone else tried using this stuff?
  14. Exeter Man
    Exeter Man
    jpwhaley,
    Looks like no-one else has tried this, but sounds like a good idea to me. As with all these things, it's always worth a try, and I think you're onto a winner with this one - just need to decorate the living room bright yellow to match ;)
    Regards
  15. Zef
    Zef
    Apr 24, 2002
    221
    Hertfordshire
    +9
    I have done this in my car with a cheap sub and amp. Works but you need to make sure you mount the sub in the hole as airtight as poss. I siliconed mine in. Gave me the fuzzy bass i needed at the time... Used a Gas Tube off cut in snazzy yellow...
