How do I wire these two together? I see it's got Ethernets in the rear! My router is downstairs & I want the music (x2 play 1s) in my bedroom upstairs. Do I need the bridge still? Down the road may get the sub to complete the system.
Temporarily wire them to your router, use your choice of App or PC controller to access them and configure/update them (including the wifi options), then you should be able to unplug them and have then connect over your wifi connection.
