ydraiggoch
I'm looking for a little bit of advice on my Sonos system expansion. I currently have a Play 5, but due to some major renovations to a Kitchen / Dining room I want to install 2 x ceiling speakers in the kitchen & 1 in the Dining Room.
To do this, I intend to buy
http://www.amazon.co.uk/dp/B001G7PL...TF8&colid=3F1DHTYC40AIV&coliid=I2ZJ2VAAB0D9PH
Along with
http://www.amazon.co.uk/dp/B003S8GH...UTF8&colid=3F1DHTYC40AIV&coliid=INT2XL1FJ7UU6
Not the best speakers I know, but due to the cost of the sonos, this is all the budget allows for at the moment.
Anyway, As I understand it, I can't have all 3 playing at once due to the impedance of the speakers. But thats fine, I'm happy to use a switch to switch on / off one of the speakers in the kitchen to allow the Dining room to play (if that will work?)
What switch would you recommend? can I get one which is controllable via an app or do you know of a smart looking wall switch? Or am I completely wrong and I don't need a switch.
Along with
