Sonos Beam vs Yamaha YSP-2700
Discussion in 'Soundbars, Soundplates & Soundbases' started by alftrad1, Aug 28, 2018.
Tags:
  1. alftrad1
    alftrad1
    Aug 28, 2018
    2
    York
    Hi guys
    Please forgive for what I am sure is a simple question but I have struggled to find clear answers so here goes...
    I'm thinking about purchasing a Sonos Beam and I know that this has a HDMI port which can be connected to the HDMI ARC on my TV. Obviously any other devices I own (Xbox One and Firestick) will then have to connect to the other HDMI ports on my TV.
    My question is, what difference does it make connecting devices directly to a TV vs a sound bar? Is there any difference? For example, the other contender for purchase is the Yamaha YSP-2700. This has 4 HDMI ports so in this instance I could connect my Xbox and Firestick directly to this device OR my TV. What are the pros and cons of either method? I just want to be clear about this before I spend money on something that forces me to connect to the TV via HDMI.
    Also, what are people's opinion on either device? WhatHiFi has the Beam as the best under £500 and the YSP-2700 as the best under £750. I don't yet own any Sonos devices but I will also get a Sonos Play 1 for my dining room with a view to adding another. It isn't impossible to think that I might also add 2 play 1s eventually as rear speakers in my living room if I went for the Beam. If I went for this, what would be the best setup out of the two? Thanks in advance!
  2. Inverary74
    Inverary74
    May 21, 2015
    23
    3
    Uk
    I think there a pro's and con's for both
    the yamaha is more flexible with the hdmi passthrough also it comes with a sub which would cost an additional 700 quid with the sonos
    you could also go the route of musiccast with the yamaha as it is a competing multiroom solution they have equivalent speakers to sonos with some new ones due to be released
    i have demo'ed both and preferred the yamaha but the sonos sounded good also
    i'm just waiting now for delivery of my ysp-2700 now
