howardlamby
Established Member
- Joined
- Dec 17, 2006
- Messages
- 342
- Reaction score
- 17
- Points
- 143
Will the Harmony 950 be compatible with the sonos beam gen 2?
Considering Harmony have stopped making the remotes and there isn't a clear ansdwer about supporting codes for new defvices and for how long (persoanlly I suspect they won't support new devices in any specific way) the only way to find out is likley to be to add a new device in the Harmony app/software for your remote and see if the device comes up. If it doesn't try a Beam gen 1 and after that you may be out of luck.Will the Harmony 950 be compatible with the sonos beam gen 2?
