I have recently fitted a Sony 48A9 TV to our new kitchen dinner extension in the snug part. I am considering a Beam 2 to give some clearer sound as the tv seems to get lost in the vaulted ceilings space. I may add rears and sub at some point, but as you can see from my signature I have a fairly decent ATMOS setup in the lounge.
I have lots of Sonos speakers already, but my question is can you play music through the Beam 2 in tandem with any other Sonos speaker like Normal? If I add rears or a sub or both, can i play my NAS and Streamed music to all speakers? I.e. will music play at the Beam, Sub and rears even if playing a stereo source?
You can control the volume with your TV remote if you connect it to the (E)ARC port of your tv.Hi everyone, can anyone tell me if the Sonos Beam Gen 2 will work without access to the app once it has been initially setup? I understand the app is essential for initial setup but can a TV remote control everything once initial setup is done?
I only own the Beam Gen 2 for a about 2 weeks so I can' t really say if you can run into problems.Thanks, could there be a point where something goes wrong and the app is required? It's for an elderly parent who doesn't have a smart phone so I can set it up initially, will it be ok or should we look at a less "smart" soundbar? They don't have any other sonos products, just looking at this as it's well reviewed.
Can that be run from a phone too or just iPad?
Have updated mine and set the height audio channels to +3, now need to test. Might dig my Nvidia shield out and run a few Atmos demos, see if I can hear a difference.
Wonder how good a job this soundbar will do as surrounds.Even cheaper than the Beam, interesting if true.
Exclusive: this is the new budget soundbar from Sonos
Keep it level otherwise you will have imbalances. For example I turned up the heights and forgot I did and as a result the football commentator was in the distance.Has anyone adjusted the height audio on the Beam 2? any difference/recommendation for settings?
If you don’t mind me asking how do you find the atmos effect compared to actual upfiring speakers of the arc?Just got my beam gen 2, swapped for an arc which was too big for my room. Just tinkering but sounds a lot bigger than it looks tbh on initial listening & am quite impressed. How do you switch off spotify if listening on the beam? Can’t seem to find an answer on how too or if you can. Thanks prob 1st of many question as well.
I have literally tried it for ten minutes I will come back to you when used it more. Tbh I didn’t really get any height effects from the arc, could be my room acoustics or layout though. So not really expecting full height effects from this eithe.If you don’t mind me asking how do you find the atmos effect compared to actual upfiring speakers of the arc?
ThanksI have literally tried it for ten minutes I will come back to you when used it more. Tbh I didn’t really get any height effects from the arc, could be my room acoustics or layout though. So not really expecting full height effects from this eithe.
There are second generation versions of all the Symfonisk speakers (bookshelf and lamp). I guess the microchip shortage has meant there is insufficient availability for the whole world. The reason they have listed the Symfonisk sets in the UK as 'last chance to buy' is because the first gen stocks are running out and the Gen 2 models haven't launched in the UK yet.IKEA now appear to have ceased production of their SONUS/IKEA Symphonisk units which were a lower cost alternative as rear speakers. There may be some residual stock around but its now listed as "last chance to buy".
watched a couple of episodes of the Mandalorian on Disney & tbh didn’t really get much of the atmos effects & I didn’t do on the arc either. It’s prob my viewing location or the room though. For its size the beam is good but the impact of the arc is a lot more forceful if you get what I mean. If I would have had a bigger room I would have kept the arc tbh, but it was too big for it. I notice the latest updates include beam height effects adjustment has anyone played around with it & had any success?If you don’t mind me asking how do you find the atmos effect compared to actual upfiring speakers of the arc?
Thanks for the honest review, I think with all these sound solutions it depends on the size and layout of the room, plus the room you have to put the soundbar on. My current q800a has ipfiring and I have the rears as well but can’t say I get much atmos effect so maybe try the arc or beam with the one sl as rearswatched a couple of episodes of the Mandalorian on Disney & tbh didn’t really get much of the atmos effects & I didn’t do on the arc either. It’s prob my viewing location or the room though. For its size the beam is good but the impact of the arc is a lot more forceful if you get what I mean. If I would have had a bigger room I would have kept the arc tbh, but it was too big for it. I notice the latest updates include beam height effects adjustment has anyone played around with it & had any success?
