Newbie3
Firstly I appreciate that some of these questions might branch across a few forums, and there are loads of them! But I thought I would get start by putting all my questions down, hopefully someone out there want to join in the fun of design a new home cinema. So please feel free to give your opinion on any element.
I have sketched out and atached the cable layout that I am intending on using with a ruff, not to scale diagram of the open-plan kitchen and Tv room. Hopefully this explains a lot?
Diagram Key
· Blue wires Cat6
· Orange wires HDMI
· Bright Red (thick) HDMI over Cat 6
· Dark Red (thin line) Speaker cable
· Green ( line out)
· Black (line in)
Because of the room layout, I thought there was an opportunity to use one of the kitchens speakers to upgrade from 5.1 to 7.1. Was going to use the following speakers:
· Front L&R and centre - B&W CWM664
· Sides - B&W CCM662 to angle the sound.
· Back B&W CCM382
· All other speakers B&W CCM 362.
· Bathroom - CCM664SR
Questions
So where I start to get a bit confused is where I should be running my music library from. I want to keep things as simple as possible, without having to switch between a bunch of apps and remotes to get all the speakers playing?
The problem I think I have with this current setup is, to get everything playing I would have to
Option 1
1) Turn a song on my iPad, (streaming form iTunes match) use airplay to push to airport express.
2) Turn on the speaker zones I want within the sonos app
3) Switch my AV Receiver source to the sonos connect.
4) Turn on the Zone 2 on my AV Receiver on.
5) And select the option/setting within the amp to distribute music to all 7.1 speakers
This sounds too complicated for my fiancé, which is my benchmark for the systems design. Any suggestions to simplify?
That leads me on too, Product recommendations.
1) What AV receiver should I get
a. it needs to have a second powered speaker zone to run the 2nd kitchen speaker
b. Also must have 7.1 channel stereo options so that I can get music playing out of all the speakers.
c. Is there an AV receiver out there, which I could programme to, by default be set up for TV sound/ movies. Then automatically recognised that when I change source to the sonos all the setting change to play 7.1 stereo? With the second zone playing? ( or even better as soon as the sonos starts is switches over to that source? When it stops switches back to 7.1 tv sound?)
d. Can I get this all for under £1000
2) Network switch to handle my setup?
3) Cat6a or 7, where to get them from in the UK
4) HDMI to CAT6 converter with IR (seem to be so many out there)
5) B&W CWM664 as centre channel speaker? Anyone used this?
Diagram Key
· Blue wires Cat6
· Orange wires HDMI
· Green ( line out)
· Black (line in)
· Back B&W CCM382
Questions
Option 1
