Hey guys, curious to hear some opinions on a setup that I am putting together.
I am planning on using the new Sonos Amp in a few zones to decrease the amount of wiring heading back to my main setup.
The sonos amp runs at 125 W per channel at 8 ohms. They also say running speakers in parallel is acceptable if they are 8 ohms each, so as to keep the circuit at or above 4 ohms.
For one of the zones I was planning to use 2 pairs wired in parallel however there specs are:
10-100W per channel/rated 4 to 8 ohms
50W IEC continuous power
handling; rated 6 ohms
Do you think that the 3 ohm load (6*1/2 since ran in parallel) is going to be too small for the amp to handle? If I am not to aggressive with the volume do you think I can avoid clipping?
