Question Sonoff basic help
Discussion in 'Smart Home, Climate Control & Security Forum' started by AlCopeland, Mar 18, 2018.
  1. AlCopeland
    AlCopeland
    Mar 18, 2018
    2
    4
    Stone, England
    Hello,
    Hope I've put this in the right section. Just after a bit of advice.
    My father in law has purchased a sonoff basic from amazon to control his outside lights. He's wired it up and I've helped to set up the app.
    When he puts power through then the lights just turn on and off constantly. There is an audible click coming from the sonoff every time the lights go on and off.
    Hope this makes sense.
  2. Jamie
    Jamie
    Jun 27, 2007
    5,361
    2
    Harrogate
    +1,389
    Is the Sonoff connected at the switch inside? IIRC the Sonoff requires a neutral which you may not have at the switch.
  3. AlCopeland
    AlCopeland
    Mar 18, 2018
    2
    4
    Stone, England
  4. giffordpikes
    giffordpikes
    Jul 16, 2017
    251
    46
    Wiltshire, uk
    +174
    In a lighting circuit in the UK that may not be live and neutral. There is usually only live and neutral at ceiling rose. I am lucky I do have live and neutral at the switch. The neutrals are wired together in a chocolate block at the back of the back box.
    Enless you have this (although its not a guarantee) then there is no neutral coming down to the switch.
