sonicstage
B
blackpoolowl
can anyone help.
i have just bought a nwhd5 put sonicstage on my desktop works fine.
i have just put it on my laptop and get the following error message:
the connected atrac audio devise must be initialized to be used with the currently installed sonicstage.
what have i done wrong can anyone help me put music on through my laptop
thx
terry
K
KJ_Palmer
Well, as it says, just initialise the HD5 and you'll be ready to go. I think you can do this from the unit itself, or (probably better), if you connect your HD5 to your PC, fire up Sonicstage and go to (Controls - Device/Media - Initialise), you'll wipe off the crappy free track and be able to start downloading you own stuff to it.
Steven
Senior Moderator
initialising deletes your songs
