Sonicstage
Discussion in 'Headphones, Earphones & Portable Music' started by bstonehouse, Mar 8, 2005.
  1. bstonehouse
    bstonehouse
    May 27, 2003
    501
    28
    +54
    I am planning to buy a HD3 and currently have all my music loaded in an old version of Sonicstage on a Sony laptop. Can anyone offer an advise about the best way to have the music structured in Sonicstage before loading it into the HD3. I currently have all my CD's in Sonicstage as a seperate playlist for each CD - will this be OK for loading to the HD3 or is there a better way to do it.
    Also, all my music is currently loaded as ATRAC3 105k - will it all have to be converted before it is loaded to the HD3..........Thanks
  2. Kaledii
    Kaledii
    Apr 11, 2002
    293
    NW
    +24
    The music files will transfer at the bit rate without a problem. If the HD3 is anything like a HI-MD player then it will transfer playlists as a group folder on the device. If individual files have an association with an album and artist then you can sort on the device.
    BTW I wouldn't recommend the 105kps codec; the atrac3plus at 64kps or Atrac3 132kps are better. Sony have just released SS3.0, which is an improvement (for instance you can choose what bit rate to transfer to the device, regardless of what bit rate it was originally encoded in) and you can download it from the US connect site. The European version will be available soon.
  3. bstonehouse
    bstonehouse
    May 27, 2003
    501
    28
    +54
    Thanks Kaledii.........will i be able to convert my songs to [email protected] before loading up to the player or will it be an option I can do when they are loaded up to the player using version 2.3. You seem to imply that only version 3 will do this.
    Many Thanks
