We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Sonicstage seperates tracks in the same album if there are different artists?
Discussion in 'Headphones, Earphones & Portable Music' started by JoachimF, Oct 21, 2005.
  1. JoachimF
    JoachimF
    Hi!
    I have just bought the NW-HD5 (it's charging right now! :clap: ) and downloaded the SonicStage 3.2. At first it actually seemed totally ok, didn't see what all the fuss was about. But when adding the soundtrack to Kill Bill Volume 1 to the library, each song became a separate album, since there are different artists singing each song. So even though the album name is the same, it seperates them...
    There must be a way of sorting this out?
    Any help would be great =)
    Regards,
    Joachim
  2. drmoze
    drmoze
    Aug 8, 2005
    196
    You can select all of the songs (ctrl-click) and then right-click on one to select 'properties', , and then check 'compilation'. If there ar elots of songs already, you can do a search by album name, then select all of those, right-click to select 'properties', then check 'compilation'.
  3. JoachimF
    JoachimF
    Ah, thank you a lot! :D
