SonicStage questions
Discussion in 'Headphones, Earphones & Portable Music' started by jordan2pip, Aug 1, 2005.
  1. jordan2pip
    jordan2pip
    1. I have several albums that I have put into SonicStage from various artists and now wish to create a playlist comprising several songs from each artist. Upon doing so, does Sonic Stage double up the songs and take twice the space, 1 in the albums section and then 1 in the playlist or does the playlist merely reference the song in the album?
    2. I have a quite a few albums from 1 artist encompassing albums, remix singles, and live recordings. Seeing as I would like to listen in 'shuffle' mode for each of these 3 unique sections, is the best way to organize the music into separate playlists for live and remixes, leaving the albums as they are?
    Thank you in advance
  2. shadowritten
    shadowritten
    1. Playlist doubles up on ACTUAL files (tracks) if you've got a HD1/HD3, but only references tracks if you have a HD5/HD5H.
    2. Again, depending on your answer to 1., playlists would probably be the most hassle-free way to do what you want.
    Hope this helps!
